yairShapira
5 years agoTES With SGMII interface - Unspecified errored packets.
Hi All. I have implemented two TSE with SGMII PCS On a cyclone V FPGA. each SGMII is connected to a PHY (MARVEL 88E1512). And the PHY's are connected to each other through RJ45 cable. I have a good...
- 5 years ago
Yes. Everything is fine now. I found out (after some try and error) that the packet length field should indicate the length of the payload + fcs field.
Thanks a lot for your help.
Best regards
Yair.
yairShapira
5 years agoHi.
It seems like I had an error building the frame resulting in payload length error.
That error is not indicated in the statistics counter so I found it after implementing monitor on the data_rx_error output from the mac.
Yair,
