RMees
7 years agoSuperlightII word alignment fails on cable.
I have ported the SuperLightII example design on a Nallatech 385 board (ARIA 10 10AX115S2F45I2SGES). The IP works fine if I use a loopback device on the QSFP port. But when I connect two ports, ea...
Nathan_R_Intel
Contributor
7 years agoIt seems with the QSFP module, the signal is degraded that you cannot achieve word alignment. Suggest to try increasing your Transmitter Vod and Pre-emphasis Post Tap 1 value to check if you can get an error free transmission.
Nathan
