RMees
7 years agoSuperlightII word alignment fails on cable.
I have ported the SuperLightII example design on a Nallatech 385 board (ARIA 10 10AX115S2F45I2SGES). The IP works fine if I use a loopback device on the QSFP port. But when I connect two ports, ea...
RMees
7 years agoAt the moment I use a Cisco QSFP-40G-SR4 module, instead of the Finisar that Nallatech has used for testing.
Finisar modules have been ordered and should arrive this week.
I think that if the transceiver toolkit test doesnt detect any errors then the physical link is not causing the problem.
As I understand it the word alignment is reached by the NIOS core adjusting the data capture.
