13 years ago
Stream to Memory sgdma problem
I am having two problems with the sg-dma in my system. My first issue is that the sg-dma ready signal goes low after the first element of streaming data, then returns high on the third. This causes the second element to be skipped. I am streaming data at the same rate as the sg-dma clock.
My second issue is that I can not re-use the descriptors. I try to set the hardware owned bit to 1 by the following command: DMA_desc[0].control=128;
The sg-dma ready signal goes high when I call the do_async_transfer() function, but it toggles low when it gets streaming data. No data is transferred to memory.
Can anyone help??
    Yes… I have been made my own dispacther and makes me cool.
    My dispatcher is nios less.
    - Nios only do initialization at first.
    - Nios get a ready address from dispatcher (like mutex way)
    - Dispatcher controls write master mSDGMA like round-robin (dual storage)
    TCP/IP troughput around 33Mbps
    14 bit ADC x 1024 length @ 2kHz samples
