15 years agoStratix IV DDR3 memory controller with Unify : simulation not working
Hello. I have a problem using DDR3 memory controller with Unify on Stratix IV. I use modelsim SE 6.5d or 10.0. My problem is that the controller is not working both with my design and Al...
15 years agoI run the simulation during 5 ms with the skip calibration enabled.
I also check the local_init_done. It os used as a enable for my application on the Avalon interface. It is because I never see my application running that I worried about the DDR3 interface. I use the controller as a stand alone without SOPC builder. I wonder why the DDR restn signal is still active after a so long time. The calibration can not be done if the DDR device is in reset state !?! I feel my problem come from warning. These mismatched connexions seem not normal for me, as the non-loading of the hex file for the sequencer. But I don't find how to solve them. Does anyone experienced the same warnings/error than I have ? Regards.
