User1573261788318367
6 years agoStratix 10M DIB timing constraints
Hi all, I have a 20 MHz DUT clock and 400 MHz DIB clock in my design (split across the U1 and U2 dies of the Stratix 10M). In the timing report I"m seeing a lot of violations between these two domai...
KennyT_altera
6 years agoWhat you can do is look into the design example/reference design how they write the PCIE constrain. From there, you should be able to determined which to used in the above.
