Stratix 10 Transceiver MGTREFCLK in LVDS
Thanks for your update and sharing of the test design. For your information, in the Fitter report, specific to transceiver refclks, the "tristate_off" = OCT is enabled. You can refer to the "Dedicated Reference Clock Pin Termination" section in the Intel® Stratix® 10 L- and H-Tile Transceiver PHY User Guide for further details.
The following are the mapping of the termination value:
1. TRISTATE_OFF: Internal termination enabled and on-chip biasing circuitry enabled
2. TRISTATE_ON: Internal termination tri-stated. Off-chip termination and biasing circuitry must be implemented
In other words, your Fitter report is showing the expected result where OCT is enabled for XCVR refclk.
So, for the XCVR_S10_REFCLK that I want to be LVDS, I should just assign them as LVDS in the Assignment Editor, and don't assign any termination, correct?
For all the other LVDS signals which have no external termination, I must assign them as LVDS in the Assignment Editor and also assign the Internal Termination as Differential, correct?
Thank you.
