HBhat2
Contributor
7 years agoStratix 10 Native PHY Usage
Hi, I have a system which uses custom interface for communication. The system transmits at 20Gbps with Spread spectrum enabled. Whether I can connect that system to Stratix 10 Transceiver using Nat...
Deshi_Intel
7 years agoHi HPB,
Your understanding is correct.
If user can control S10 Ltile/Htile CDR incoming refclk ppm below 1000 threshold then it should be safe. CDR should be able to lock
Do take note that for S10 Etile the CDR ppm tolerance spec is just 750, not 1000.
dlim
