roeekalinsky
Contributor
4 years agoStratix 10 Mailbox Client IP: max input clock frequency specification
In the user guide documents for the Stratix 10 Mailbox Client IP (both versions, both with and without Avalon Streaming interface) there is a comment indicating that the input clock frequency is limi...
YuanLi_S_Intel
4 years agoThe recommended max input clock for Mailbox Client IP is 250Mhz. If you are putting higher clock frequency, you will need to make sure that you can close timing properly else they might end up running at slower speed.
