Stratix 10 E-tile Hard IP for Ethernet, 10GE with external AIB clocking error
## 1. What we did since the first report
**Workaround in use (works):** each channel has its own glitch-free clock switch (Stratix 10 Clock Control IP) in
front of i_aib_clk / i_aib_2x_clk and i_sl_clk_tx / i_sl_clk_rx:
- 25G: 402.83 / 805.66 MHz from an E-tile Native PHY in PLL mode (as in the design example).
- 10G: 161.13 / 322.27 MHz from a second Native PHY PLL (refclk 156.25 MHz), TXMAC_EHIP_CFG flowreg_rate = 3.
- Switch sequence: PMA disable, analog reset, TX / RX ratio, clock switch while the channel is held in reset, channel
reset, Ethernet registers 0x37A / 0x37B, width, phase slip, PMA enable, RX adaptation (from c3_reconfig.c).
Results with the workaround: 10G and 25G, any channel at any rate independently, 0 FCS errors in all tests (80+
traffic tests of 2 s, 5-round switching loops, timed replay of 17,556 frames bit exact, PMA PRBS31 600 s with 0 errors
at both rates). 25G + RS-FEC (Clause 108) on single-channel instances also works, including run-time switching
25G <-> 25G + RS-FEC <-> 10G with the register values of c3_reconfig.c.
## 2. Re-test of the documented scheme (402.83 MHz AIB clock at 10G), 30-Oct-2026
Same image, two channels on one E-tile (ch 16 and ch 1) linked by SFP28 modules and fibre. 10G, TXMAC_EHIP_CFG =
(read & 0x7E07) | 0x9FFF8108 (flowreg_rate 4, as c3_reconfig.c 25gnofec_to_10g and as the register description "4: 10G
(with PTP or when External AIB clocking is enabled)"), XUS_TIMER_WINDOW 0xC4E3, BER_INVALID_COUNT 0x10, i_aib_clk /
i_sl_clk = 402.83 MHz. MAC statistics, 2 s per test:
| Test | Result |
| Reference: both channels 10G on 161.13 MHz, flowreg 3 | 14.21 M frames each way, 0 FCS |
| flowreg 3, both channels on 402.83 MHz | TX not throttled (30.2 M frames accepted), TX FIFO over / underflow, far end 1.0 M good + 8.9 M FCS errors |
| flowreg 4, both channels on 402.83 MHz, full duplex | MAC throttles to line rate (19.4-19.8 M frames), no TX FIFO over / underflow, 0.84 % FCS each way; RX status shows hi-BER / fault / CRC events |
| flowreg 4, only channel A on 402.83 MHz, B on 161.13 MHz | B -> A (RX on 402.83 MHz): 14.21 M, **0 FCS**; A -> B (TX on 402.83 MHz): **2.4 % FCS** |
| flowreg 4, A transmitting alone (simplex) A -> B | run 1: 1 FCS error in 18.7 M; run 2: 9.3 % FCS |
| flowreg 4, timed replay of a real 10G traffic pattern (17,556 frames, below line rate), A -> B, 5 runs | every run 5.4 % FCS (936-947 frames) and 3,054 frames sent late (the MAC accepts data slower than the schedule needs); same replay on 161.13 MHz: 0 FCS, 0 late |
Conclusion: with a 402.83 MHz AIB / client clock at 10G the **receive** path is error free, the **transmit** path
corrupts 2-9 % of the frames (varying between TX restarts at line rate, constant 5.4 % with real traffic) and cannot
keep a timed schedule. This matches the 27-Oct report (custom cadence variants also failed).
## 3. Why the documented scheme matters for us now: RS-FEC on more ports
- One RS-FEC block serves 4 lanes, and one IP instance must own the whole block (E-Tile PHY UG 683723 p48; our Fitter
error 175001 with two single-channel instances on ch 0 and ch 1). To have RS-FEC on several ports of one block we
need a multi-channel instance.
- The multi-channel instance (generated with 4 channels, first_lane0) has **one** i_aib_clk / i_aib_2x_clk for all
channels, so our per-channel 10G clock is not possible inside it. Per-channel 10G / 25G then requires the
402.83 MHz scheme of Ethernet UG 683468 p172-173 (Figure 63: "You can reconfigure the master channel to any mode
without bringing down the slave channel functionality"), which fails on TX as shown above.
## 4. Questions
1. Is 10GE TX with external AIB clocking at 402.83 MHz and flowreg_rate 4 expected to work without frame errors? If
yes, which further settings are needed (EHIP / PCS / AIB adapter registers, TX FIFO thresholds, i_sl_custom_cadence,
ready latency)? Can you provide a configuration that has been verified in hardware with continuous traffic at line
rate?
2. In a multi-channel 10GE/25GE instance with external AIB clocking, is there any way to clock individual channels
differently (e.g. per-channel AIB clock), so that one channel runs 10G at 161.13 MHz while another runs 25G?
3. Is our per-channel clock switch (Clock Control IP in front of i_aib_clk / i_aib_2x_clk / i_sl_clk, switched only
while the channel is held in reset) a supported use of external AIB clocking?
4. PHY UG 683723 p117 Figure 60, note 1 on RSFEC_1 (ch 4-7) and RSFEC_4 (ch 16-19): "This block cannot be used in
combination with EHIP_CORE - fractured bypass." Please explain the restriction: we use RSFEC_4 (ch 16, first_lane0)
with a single-channel 25G + RS-FEC instance (Fitter accepts it) and plan RSFEC_1 (ch 4).
5. Documentation remark: in the DR example c3_reconfig.c (25gnofec_to_10g) the comment says "flowreg_rate 3 -> 4
3:10G, 4:25G", while the register description (Ethernet UG 683468 p228) says "3: 25G or 10G (without PTP), 4: 10G
(with PTP or when External AIB clocking is enabled)". The code writes 4 for 10G; the comment appears to be reversed.
