Amir_Nassie
5 years agoStratix 10 Dual-Port RAM (with 2 clocks) generation problem
Hi, i'm converting my Stratix V design to Stratix 10. in Stratix V i used the MegaWizard in quartus (13.1 i think) to create an SRAM with: 2 read+write ports 512 rows of 128bits each (same data ...
- 5 years ago
If you look into https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/stratix-10/ug-s10-memory.pdf Table 10, it will shows that Stratix 10 does not support True Dual Port with byte enable features.
JohnT_Altera
5 years agoHi,
I would recommend you to use "Dual Clock: use separate 'input' and 'output' clocks" setting.
Amir_Nassie
5 years agoThanks,
but how do i get the 2 read+write ports (each in a different clock domain) functionality ?
