HBhat2
Contributor
7 years agoStratix 10 - Transceiver reconfiguration settings for 10G and 20G link rate
Hello, I am using Stratix 10 SoC Dev kit for high speed communication PoC. The communication link must negotiate to either 10G or 20Gbps link rate. If I see the Native PHY for Stratix 10, I need to ...
- 7 years agoHi HPB, You are right, the note seems confusing. For your information, I have consulted Factory and get to know that this feature is already supported with the current latest Quartus release ie 18.1Pro. This seems to be a typo in the user guide and I have filed a case to remove the confusing note on future release support. Sorry for the inconvenience. Please let me know if there is any concern. Thank you. Best regards, Chee Pin
CheepinC_altera
7 years agoThanks for your update.
- HBhat27 years ago
Contributor
I was reading "6.9.3. Reconfiguring Between GX and GXT Channels" and found below statement.
"Dynamic reconfiguration between GX and GXT datarates will be supported in a future Intel Quartus Prime Pro Edition release."
Although, now I am able to configure 2 dynamic reconfiguration profiles with 10gbps(GX data rate) and 20Gbps (GXT data rate) in the Platform designer /qsys and able to generate HDL, above statement is creating some doubts.
With Regards,
HPB
