12 years agoStore scalar variables in DSP Adv
I used DSP Adv block to build a module which includes tens of scalar variables. I used to different dualmem blocks to store and modify them. Is there another efficient way to store? Thanks J...
12 years ago --- Quote Start --- A register may be a Z^-1 block. --- Quote End --- yes it is sample delay block(in ModelPrim library) and if set to 1 then infers a register and carries symbol of z^1. BTW xilinx SysGen(equivalent to Altera ADSPBuilder) has delay block as above but also has separate register block. Their register block has ports for reset and enable. Altera's sample block is naked of ports apart from D&Q
