Minh_Le
4 years agoSimulation unbound warning
I'm working on simulation with IP cores and having issue with unbound components. Specifically, the Questa compiler complains about the dcfifo mixed width have declared and instantiated interfa...
ShengN_altera
4 years agoHi Minh,
Check out this https://www.intel.com/content/www/us/en/support/programmable/articles/000081035.html.
I simulate the fifo using testbench system and don't get any not bound warning for missing port 'eccstatus'. See the file attached.
Does it affects your simulation result? If not probably you can just ignore the missing port 'eccstatus' warning.
Sheng
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
