Minh_Le
4 years agoSimulation unbound warning
I'm working on simulation with IP cores and having issue with unbound components. Specifically, the Questa compiler complains about the dcfifo mixed width have declared and instantiated interfa...
Minh_Le
4 years agoHi Sheng,
Thanks for your response. So the fifo won't work with ECC disable? Is the memory block type must be M20K for the fifo to work? The design has been deployed already and the testbench is being developed for future expansion purposes. We prefer to minimize the change to IP cores as much as possible.
-Minh
