VMR001
6 years agoSimulation of EMIF example design not moving forward
I have generated an example design and tried to simulate the design (the scripts were generated by quartus pro tool) using Modelsim-Intel FPGA edition, It has been running for 1+ hour, I am not seein...
NurAida_A_Intel
6 years agoHi Sir,
Just to provide additional info here regarding the estimated simulation times for Stratix 10. As you can see below is the estimated time taken to complete the calibration using the Synopsys VCS (the fastest simulation tool). For, Modelsim, it might be much longer compared to Synopsys VCS. However, this table is just the estimated time and it may varies depending on the IP configuration, the simulator used, and the computer or server used. I suggest you to also try using other simulation tools (For eg : synopsys VCS simulation run time is much faster as compared to other tools) to see if this help to improve the simulation speed.😊
Aida
