TSchu3
6 years agoSimulating Triple Speed Ethernet, Decryption Fails
Hello, I am trying to simulate the TSE testbench IP generated with Quartus Prime Standard 18.0. My simulator is Cadence Xcelium. Xcelium cannot decrypt the TSE testbench submodules. I have not enco...
Deshi_Intel
6 years agoHI Travis,
I carefully read back the EDA support plan table from Quartus release note doc and finally found out the answer is there all the while. Sorry, I didn't catch it earlier.
Let me attached the screen shot and explain to you again.
- For Cadence sim (IES) for both Quartus std and pro, there is bracket (64-bit Linux only) – I understand now this is referring to support in Linux OS only
- If we look at Mentor Modelsim SE, it’s bracket (64-bit only) – this means it’s supported on both Win OS and Linux OS
- If we look at Aldec Active-HDL, it's bracket (32 bits win only) - this means it's supported in Win OS only
I hope I clarify your doubt now.
dlim
