Simulating RS232 UART IP Core in VHDL
Florian,
Arria V both nativelink and setup script methods (do file .../testbench/mentor/test.do) can be simulated for RS232 UART using VHDL. Check the sample file attached below. I further try out with Arria II, Cyclone V and Stratix V all can work properly.
Ya. UART {RS-232 Serial Port) Intel FPGA IP only supports memory mapped. IRDA UART under university program got the same problem with VHDL language on Arria 10 as well.
Sheng
Hi Sheng,
I don't understand how you were able to simulate the attached files. When I run the mentor/test.do script with modelsim following warning message appears:
# ** Warning: (vsim-3473) Component instance "rs232_0 : unsaved_rs232_0" is not bound. # Time: 0 ps Iteration: 0 Instance: /unsaved_tb/unsaved_inst File: <path>/test/unsaved/testbench/unsaved.vhd
Also there is no file regarding the rs232 in the unsaved_tb/simulation/submodules folder:
This seems to be the same behaviour that I have seen on my computer when trying to simulate with the device set to Arria V.
Best Regards
Florian
