Simulating RS232 UART IP Core in VHDL
Hi Florian,
You can change device family in Quartus main window and create new qsys project. Or go to View/Device Family in platform designer to change it.
May be you can replace RS232 UART with UART {RS-232 Serial Port) Intel FPGA IP as alternative. Both are similar.
Sheng
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
Hi Sheng,
I have installed and tried to use Arria V but it still says that for rs232 no files were generated for fileset SIM_VHDL.
Which device family did you use?
I have tried using the UART you mentioned above, but unfortunately it doesn't support the stream mode that the "old" UART has. It only supports the memory mapped mode.
Florian
