FHint
4 years agoSimulating RS232 UART IP Core in VHDL
I am currently working on a FPGA design containing a UART interface and have choosen the Intel RS232 UART IP Core from the University Program to use for this.
I would like to simulate the ...
FHint
4 years agoHi Sheng,
I have tried to take a look at the unsaved_tb.qsys system you had attached, but the platform designer cannot find the component, as you can see in the following image.
I am using the Quartus Standard 19.1 edition - is that a problem?
Florian
ShengN_altera
4 years agoHi Florian,
I think there are some files missing there. Below attach another file for your reference. Try to remove unsaved.qsys and include only unsaved_tb.qsys which is .qsys file of testbench system generated. Then do compilation and RTL simulation. You can add more signals by right-clicking in modelsim object panel or use command add wave -r /*
Sheng
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
