13 years agoSimulating custom DDR controller with ALTMEMPHY using ModelSim-Altera Starter edition
I'm designing a custom DDR controller using one instance of the ALTMEMPHY generated with the MegaWizard Plug-in Manager. The simulation files generated using Quartus II version 11.1sp2 or 13.0sp1 are...
13 years agoYou should be able to already simulate your design, since it should have produced a .vo file for the VHDL that is included by the .do scripts.
It gets awkward when you need to actively edit the VHDL and rerun your simulation. The best I came up with was to modify the VHDL in a separate Quartus project that compiled it to .vo, which then got included in the primary Modelsim environment. It was not a very productive arrangement, but I didn't need to work in it too much so it was OK.
