Significance of the Descriptor_ID field used by the the PCIe-Avalon-MM-DMA IP core?
- 6 years ago
Hi ,
In a way your pointer is correct and the descriptor id is written by software,
should the application logic writes "1" or "0" to RD_DMA_LAST_PTR ?
>>1
Hello RahulS_Intel,
Thanks for your reply.
I read page 9 in the doc as you instructed. Unfortunately, it didn't answer my question. My question was about the rationale of the design decision for having a Descriptor_ID field in the descriptor table. I think the field is unnecessary. This is because the offset of a descriptor from the Descriptor Base Address already gives its ID. For example, the Status portion (with "Done" bits) of the Descriptor Table does not need a Descriptor_ID field. Please see the excerpt below.
What happens if the application logic writes a "1" to the Descriptor_ID field of Descriptor 0? To start the Read DMA process for this descriptor, should the application logic writes "1" or "0" to RD_DMA_LAST_PTR ?
Ari
