JBayl
6 years agoSerial Flash IP page program
This support request is a continuation of a previous post i made that i no longer have access to, with subject: What's the EPCQL Page Program sequence when using Serial Flash IP on a Cyclone 10GX wit...
JohnT_Altera
6 years agoHi,
There is no special way to access through the PCIe interface. You will need to make sure that you are accessing to the correct location of the Serial Flash IP.
- JBayl6 years ago
We think we are accessing the correct location. We have used the JIC you've provided and the SW still doesn't work. Do you see anything wrong with the code I have attached?
