Gyud0
3 years agoHey,
My answers:
- Which SDRAM Controller IP that you are using? SDRAM Controller Intel FPGA IP
- Which Quartus version and edition that you are using? Quartus 20.1 Prime
- Which device that you are working on? Cyclone V
- Are you using Intel Dev Kit or your own custom board? A custom board
- Are you using an example design or your own design? No
- Any memory datasheet and user guide that you are referring to? Yep, I'm using the MT48LC16M16A2:https://www.micron.com/-/media/client/global/Documents/Products/Data%20Sheet/DRAM/256Mb_sdr.pdf
I'm repeating again that I see that the SDRAM eject the correct data via it's Address and data port (that connected to the FPGA- Via SignalTap), but the data that I got from the IP equales to x"FFFF" synchronized to avmm_readdatavalid pulse.
