SDRAM BeMicro Max 10
- 5 years ago
You created the IP in a Platform Designer system and didn't connect anything to it.
It would probably be best to start with an example design. You can download example designs for different versions of Quartus here:
I'm trying to instantiate a SDRAM Controller from Quartus II -> Tools -> Platform Designer -> Memory interface and controllers ->SDRAM -> SDRAM Controller.
I set the timing parametters according with my SDRAM datasheet:
But I obtain two errors.
This is the correct way for to use my BeMicro 10 SDRAM?
Why I obtain the errors?
