DB
6 years agoSDI II IP Core - HD-SDI dual link to 3G-SDI conversion
CheepinC_altera
6 years agoHi,
Sorry for the confusion. Thanks for the clarification. As I understand it, you would like to convert two parallel HD SDI data streams into one 3G SDI serial data stream to be sent out. For your information, this is not supported by the SDI II IP. The SDI II IP can take in two serial HD-SDI data stream and convert to one 3G parallel stream. Sorry for the inconvenience. You might need to look into coding your own converter to merge the two parallel HD SDI into a parallel 3G SDI before feeding to SDI II IP (configured in 3G mode).
