AlexR
7 years agoSDI II IP - TX sync Issue
Hi, In the CycloneV GX project, I configured the SDI II core as follows: bidir, 3G SDI only, transceiver and protocol, CMU, dynamic switching off. I found out that the SDI output in my project is...
AlexR
7 years agoHi SK Lim,
>Each Transceiver bank has 6 channels with two CMU PLLs that you can use for the duplex SDI loopback.
I wanted to clarify: there are two CMUs in each bank or in the whole chip? Chip is 5CGXFC4C6F23. I placed in the project two channels SDI loopback. Below is a screenshot from the Chip Planner ("канал"="channel"). The third channel does not fit, as there is not enough space for the location of the third channel cmu_pll.tx_pll.
Thanks for your help.
Best regards, Aleksander
