HBhat2
Contributor
5 years agosd_threshold setting in Quartus for transceivers
For Arria 10 devices, below sd_threshold option can be given in QSF file.
For your reference, as per the A10 user guide, in SATA application, the following values are used:
For SR: s...
CheepinC_altera
5 years agoHi HPB,
As I understand it, you have some inquiries related to the signal detect threshold settings. As I further look into the user guide and cross check with Quartus Assignment Editor, I understand that the threshold would be dependent on the "Receiver Link Type" assignment in Assignment Editor. You can choose LR or SR for this. There is no direct QSF assignment to set the SDLV values. After the Fitter compilation, you can check the GXB Reports -> Receiver Channel -> "HSSI PMA RX SD" on the Fitter auto-assigned value.
Chee Pin
