mark_lee
5 years agoscalable_10GE_MAC_NativePHY_design
I run the example "scalable_10GE_MAC_NativePHY_design" to TEST 1588 PTP ,but I can not get the correct "delay"time and "offset"time . it's still get "0". the output message is:
% TEST_1588 0 1 10G ...
Deshi_Intel
5 years agoHi Mark,
Just to quick check with you, are you referring to below example design ?
If yes, then have you followed the test procedure as specified in the user guide doc like
- page 9, clock controller GUI setting
- Ensure you connect the SMA cable correctly on the correct SMA port on A10 SI kit board. Double check on the differential pair channel positive vs negative pin polarity
- page 14, Lastly, you can also refer to signal_tap file to assist you in debugging your hardware test result to validate which status signals are failing vs the golden signal_tap result in page 14,15
Also, did you modify the ref design itself ?
dlim
- mark_lee5 years ago
Thanks Deshi and team ! I will try.
