JJame30
6 years agoSATA 2 in Quartus 14.0
Hi, I am working on 2.5'' SATA II SSD (WR2SF256G-JFITI). using ALTGX ip for transceiver configuration. kindly share reference documents for configuration settings details for speed negotiation using...
CheepinC_altera
6 years agoHi,
For your information, regarding your previous note on the MIF info mapping, in the reduced MIF, the 6 MSBits of the MIF data = reconfig address while other LSBits = reconfig data. The MIF file is generally stored inside a ROM. You may then connect the 22 bits output of the ROM according to the port mapping mentioned to reconfig_address and reconfig_data at top level.
Thank you.
