SATA 2 in Quartus 14.0
As I understand it, you have some inquiries related using SIV device for SATA. To ensure we on are the same page, would you mind to further elaborate on "reference documents for configuration settings details for speed negotiation using ALTGX_RECONFIG"?
For example, what is the configuration settings details that you are referring here?
Just wonder if you have looking for some documentation which discuss about rate change for SATA application in SIV devices? If yes, you may try to refer to AN 625 - Implementing SATA and SAS Protocols in Altera Devices (https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an635.pdf) to see if it is helpful to you.
Chee Pin
Sir,
For SATA 2 effective data rate is 3000 Mbps. Then why speed negotiation is required? we can set data rate in ALTGX as 3000 Mbps directly. right?
