Ajas
5 years agoRx block lock in E-Tile Hard IP for Ethernet
I am doing simulation using E-Tile Hard IP for Ethernet with 25G x 4channels . Tx serial lines are looped back to Rx.
Rx_block_lock signal is getting asserted for the first time reset is re...
SengKok_L_Intel
5 years agoIn your simulation, you may check the local_fault signals again after the *_ready signals are asserted.
- Ajas5 years ago
Thank you for the suggestion.
Could you please suggest any reason for local_fault to be asserted? as it stays high even after the ready signals(ehip_ready, tx_lanes_stable) are asserted?
