Ajas
5 years agoRx block lock in E-Tile Hard IP for Ethernet
I am doing simulation using E-Tile Hard IP for Ethernet with 25G x 4channels . Tx serial lines are looped back to Rx.
Rx_block_lock signal is getting asserted for the first time reset is re...
SengKok_L_Intel
5 years agoBelow is what I observed in the simulation:
After asserted tx/rx rstn again, the IP will take some time to block lock, and then asserted the *_ready signals.
During this period, the signal may not stable, and the local_fault signal can be asserted. However, after the *_ready signals are asserted, the local_fault signal will stay low.
This is NOT expected if the local_fault signal always stays high after de-asserted the tx/rx rstn.
