Ajas
5 years agoRx block lock in E-Tile Hard IP for Ethernet
I am doing simulation using E-Tile Hard IP for Ethernet with 25G x 4channels . Tx serial lines are looped back to Rx.
Rx_block_lock signal is getting asserted for the first time reset is re...
SengKok_L_Intel
5 years agoI was running with Ethernet without 1588 enabled.
- Ajas5 years ago
Thank you for the reply.
I am running with PTP configuration. As soon as the tx/rx_rstn de-asserted, local_fault signal is also asserted. Could you please suggest in which scenario in simulation, local_fault would assert, incase of loopback?
