Ajas
5 years agoRx block lock in E-Tile Hard IP for Ethernet
I am doing simulation using E-Tile Hard IP for Ethernet with 25G x 4channels . Tx serial lines are looped back to Rx.
Rx_block_lock signal is getting asserted for the first time reset is re...
SengKok_L_Intel
5 years agoI have performed a simulation by asserting the sl_tx_rst_n & sl_rx_rst_n signals for 10 clock cycles after the rx_block_lock signals are locked.
Please refer to the attached simulation waveform, after triggered the sl_tx_rst_n & sl_rx_rst_n signals, the rx_block_lock becomes 0, however, after some time, it is able to lock again.
Therefore, I don't see the problem that you encountered, perhaps, you may need to run the simulation slightly longer to see if this is able to lock.
- Ajas5 years ago
thank you for the response.
is it with PTP configuration or only Ethernet?
