NHuen
6 years agoRSU and ASMI Paralel. Safe Update and Reset-Handling
Hi together, I have several questions on our new development containing two Cyclone 4GX devices. One EP4CGX22 and one EP4CGX15 each with its own EPCQ16A. Everything in AS. No dependency between the ...
YuanLi_S_Intel
6 years agoHi Nils,
Please find my response below:
1) When you said about reset? Which reset are you referring? If you are saying about "remote system upgrade registers", it will be reset by the IP itself.
2) The check is on the application image. I dont think is small part.
3) You can choose to boot into factory / application. All you need to do is to set ANF to 1 (application) or 0 (factory)
Thank You.
Bruce
