NHuen
6 years agoRSU and ASMI Paralel. Safe Update and Reset-Handling
Hi together, I have several questions on our new development containing two Cyclone 4GX devices. One EP4CGX22 and one EP4CGX15 each with its own EPCQ16A. Everything in AS. No dependency between the ...
YuanLi_S_Intel
6 years agoFor the first question, you mentioned that you need a external max10 device just to perform reset to internal logic. May i know which internal logic are you refering to? Cyclone IV FPGA?
Second question, yes. Checking will be applied when you are perform remote update say, from factory image to application image and vice and versa. If there is CRC error and etc, it will revert back to factory image.
Third question, apologize i dont understand about this. May i know which document are you refering to? What is the page?
