LFahem
7 years agorst_n port on the pll is not properly connected
Hello I am working on a project containing several submodules. One of them contains a PLL that gets its reset signal from a reset generation block instantiated in the main project. The problem is th...
- 7 years ago
I am sorry for not updating my case. Actually, I have found an error in my reset generation bloc that makes the reset signal always stuck on '0'. Thus, the synthesis tool, makes his optimisation process by deleting the reset bloc with other design parts. Then it considers that the reset signal of the PLL is not connected which generates this error message.
Thank you for your help.
Lotfi.
Vicky1
7 years agoHi,
Could you please check the below solution & old thread?
https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/component/2017/14--why-do-i-see-the-error-error--rstn-port-on-the-pll-is-not-pr.html
https://forums.intel.com/s/question/0D50P00003yySnZSAU/reset-for-pll
Vicky
