GDagi1
6 years agoRGMII data not passed to AvalonST
Hi all, I am currently attempting to take in 4 bit RGMII data into my system and then modify the resulting 32 bit AvalonST data. My testbench sends this data currently and it appears as RGMII inputs...
Deshi_Intel
6 years agoHi,
You don't need to do anything extra in these 2 forum cases. Let me help you.
Below is what I am going to do.
- I will copy over your latest debug discussion into support case opened by Andy (Arrow dFAE)
- Then, I will close these 2 forum case to avoid confusion
- After that, we all can move on to discuss debug plan in Andy's case.
Btw, you have the right mindset in moving the debug plan
- It's good to know reg_busy is no longer stuck high. Let's resolve whatever issue that you may have with Avalon configuration bus as it's essential to configure TSE IP correctly first before we look into functionality issue
- Once we sorted out all the configuration issue then we can look into the Avalon ST RX interface no data coming out issue
dlim
- GDagi16 years ago
Alright dlim, sounds good.
When you can, please direct me to the new post for discussion.
Thanks again,
-George
