ESama
6 years agoRef Clock problem in the simple_socket_server exemple based on the Triple Speed Ethernet for Cyclone 10 GX Development kit through Quartus 18.1
Hello I get the following error when I try to compile with quartus 18.1 the simple_socket_server exemple given for the Cyclone 10 GX dev kit : "Error(18694): The reference clock on PLL "sss_qsys_i...
NikoR
6 years agoHi.
The link you provided is broken...
Do you have an updated link that works? I would like to see it...
Nikolay
ESama
6 years agoHello Nikolay
Please find below a new link to the zip file.
https://we.tl/t-P3EMrZrg3x
The original request were:
Triple Speed Ethernet : Low data rate with Simple Socket Server exemple
I 'm using the simple_socker_server exemple proposed with the Cyclone 10GX dev kit. The FPGA card is connected to a PC through a 1 Gbps Ethernet link. The exemple is working well with out any PB. In order to evaluate the data rate performance, I added in the SSSSimpleSocketServerTask a loop to transmit 10 000 time a buffer of 1 ko with the send() function. The transfer takes 8 s to be completed. By replacing the FPGA dev kit by a socket server implemented in a PC through the same 1 Gbps Ethernet link, the transfer takes roughly 0.2 s. Where does the problem com from ?
Thank you for your help
Best regards
Etienne Samain
SigmaWorks
Le 18/02/2020 à 14:07, Intel Forums a écrit :
