ESama
6 years agoRef Clock problem in the simple_socket_server exemple based on the Triple Speed Ethernet for Cyclone 10 GX Development kit through Quartus 18.1
Hello I get the following error when I try to compile with quartus 18.1 the simple_socket_server exemple given for the Cyclone 10 GX dev kit : "Error(18694): The reference clock on PLL "sss_qsys_i...
Deshi_Intel
6 years agoHI,
You can refer to below link for the solution.
- https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/ip/2019/error--18694---the-reference-clock-on-pll--qsystop0-a10tsemacpcs.html
dlim
- NikoR6 years ago
Hi.
The link you provided is broken...
Do you have an updated link that works? I would like to see it...
Nikolay
- ESama6 years ago
Hello Nikolay Please find below a new link to the zip file. https://we.tl/t-P3EMrZrg3x The original request were: Triple Speed Ethernet : Low data rate with Simple Socket Server exemple I 'm using the simple_socker_server exemple proposed with the Cyclone 10GX dev kit. The FPGA card is connected to a PC through a 1 Gbps Ethernet link. The exemple is working well with out any PB. In order to evaluate the data rate performance, I added in the SSSSimpleSocketServerTask a loop to transmit 10 000 time a buffer of 1 ko with the send() function. The transfer takes 8 s to be completed. By replacing the FPGA dev kit by a socket server implemented in a PC through the same 1 Gbps Ethernet link, the transfer takes roughly 0.2 s. Where does the problem com from ? Thank you for your help Best regards Etienne Samain SigmaWorks Le 18/02/2020 à 14:07, Intel Forums a écrit : - Deshi_Intel6 years ago
HI Nokolay,
Yup, looks like the KDB link is broken. You can refer to attached pic for KDB detail first.
I will feedback to Intel IT to fix the link.
dlim
HI Nokolay,
The broken KDB link is now fixed.
dlim
