Additionally, I have examined the following links (in my effort to simulate the FFT IP):
Unable to simulate designs comprising FFT (ModelSim Intel FPGA Starter Edition 10.5b and 10.6d) - Intel Communities
AN 320: Using Intel® FPGA IP Evaluation Mode (d2pgu9s4sfmw1s.cloudfront.net)
The first link, from the forum, has an explanation about 'compilation order' of certain FFT IP files, but it is not clear how to accomplish changing the file order. I tried it a couple of different ways, such as in Project Navigator (in Quartus IDE) but I was not able to change the file order, let alone know if this is even an overall valid solution.
As for the second link, regarding IP Evaluation Mode, I checked in Quartus under Assignments -> Settings -> Compilation Process Settings -> More Settings
Under More Settings, for Intel FPGA IP Evaluation Mode, I made sure the Setting: was 'Enable'. This was the default setting, as well.
I am still looking for a way to simulate this FFT IP before purchasing a license.
