Thank you for your question regarding implementing a simple test design with the Agilex 5 GTS transceiver.
To help you get started quickly, I recommend referring to the IP-generated example design described in the GTS Transceiver PHY User Guide under the section “GTS PMA/FEC Direct PHY IP Example Design.” You can select an example design that is closest to your target configuration, verify its functionality, and then proceed with customizing it to meet your specific requirements. Generally the example designs support simulation and hardware.
Please let me know if you have any further questions or need additional clarification. Thank you.
