XQSHEN
6 years agoQuestion about UniPHY with DDR2
1) avl_size only has 3 bits, how to set burstcount = 8?
2) during ddr2 simulation using intel model, there are two many avl_ready = 0 even I set avl_size = 3'd4;
It significantly impact the data ...
- 6 years ago
avl_size is generated according to the maximum AVMM burst length, the default length is 4, this is why you will find the signal is only 3bits. You can enlarge burst length is you want to improve efficiency of controller.
ybin
6 years agoHello,
- XQSHEN6 years ago
Should that setting impact the burst length of below?
- ybin6 years ago
The setting you mentioned doesn't impact avl_size, but it can impact efficiency, the default value is 8, no need to modify it. You can just modify maximum AVMM burst length value.
- XQSHEN6 years ago
Thanks, it's clear now. You can close this topic.
