dsun01
Contributor
4 years agoquestion about QSPI core
Dear Intel Support and Expert
I am working on a QSPI project, the target device is STHV1600 from ST. the chip control is like QSPI, but I think need some customization.
If there is no QSPI IP ...
JohnT_Altera
4 years agoHi,
Not sure if you are able to use https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-gen-sfi.pdf? I don't think you are able to modify the QSPI Core IP as it is part of the Quartus IP.
- dsun014 years ago
Contributor
Hi John
thank you for the reply, if there is no similar core that I can use, is there a solution that use the NiosII IO to emulation a Quad-SPI? if true, is there are example how to use NiosII implement an SPI through the IO pin instead of a SPI MASTER core.
David
