13 years agoquestion about altgx simulation
I'm working on the transceivers of a Stratix IV GX230 FPGA in basic mode. In the megawizard, I'm using the following settings: -Protocol : Basic -Subprotocol: None -operation mode: Receiver and Transmitter -Number of Channel : 1 -deserializer block width: Single -Channel Width: 8 -Input clock : 160MHz -Data rate :1600Mbps -8b/10b mode : normal I transmit the control data K28.5(0xBC) continuously. The problem is the signal "tx_dataout" is unknown but not serialization data in simulation wave. Attachments is my simulation wave. regards1 Reply
- LXI001
Hello, I have encountered the same problem with you. How do you solve it? Looking forward to your reply
