LZhi01
6 years agoquartus 19.4 can not use more than 2 clocked video output II IP at one project?
hello,when i use 2 clocked video output II IP,one is separate mode for HDMI interface,one is embedded mode for SDI interface,but the project can not compiled successfull. The quartus(version 194) r...
Deshi_Intel
6 years agoHi,
Yes, I am reviewing and debugging your project.
This issue looks like missing "sdi_cvo_rden" port generation in CVO IP. I can see that you already enable "embedded in video" option in CVO IP.
I plan to try out few more debug from my end but if still failed then I will file investigation report to CVO IP developer to look into issue.
Will keep you posted on issue status update.
Deshi
