LZhi01
6 years agoquartus 19.4 can not use more than 2 clocked video output II IP at one project?
hello,when i use 2 clocked video output II IP,one is separate mode for HDMI interface,one is embedded mode for SDI interface,but the project can not compiled successfull. The quartus(version 194) r...
Deshi_Intel
6 years agoHi,
- May I know is this Quartus synthesis error or fitter error ?
- Also have you traced the design files as indicated in the error message, is the error coming from CVO IP used to interact with HDMI IP or SDI IP ?
I checked VIP user guide on the usage of sdi_cvo_rden.
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_vip.pdf
- Have you enabled this port correctly as shown in (page 79, table 31) and also connect the port correctly as shown in (page 29, figure 14) ?
dlim
