10 years agoQuartus 15 ALTLVDS_RX MegaWizard Errors
I'm trying to create IP ALTLVDS_RX for project with Cyclone V.
But with defaults parameters MegaWizard saysError: Parameter VALID_PHASE_INCLOCK has been assigned the value 0.00 which is incompatible with the current settings of DESERIALIZATION_FACTOR(4), INPUT_DATA_RATE(800), INTENDED_DEVICE_FAMILY(Cyclone V), LE_SERDES(UNDEFINED), LVDS_RX(UNDEFINED), PLL_FREQ(UNDEFINED), USING_FLEXIBLE_LVDS(UNDEFINED). The legal value is 0,00|22,50|45,00|67,50|90,00|112,50|135,00|157,50|180,00|202,50|225,00|247,50|270,00|292,50|315,00|337,50|
Error: Parameter VALID_PHASE_RXIN has been assigned the value 0.00 ...
It gives Error if I check "use external PLL" "What is the phase alignment of 'rx_in' with respect to 'rx_inclock' " suggests 0.00 and nothing more. I have not found parameters which changes Parameter VALID_PHASE_INCLOCK error . How can I solve this problem? Did anybody used ALTLVDS_RX with Quartus 15 and Cyclone V ?17 Replies
--- Quote Start --- That sounds like a bug that needs to be reported! Not uncommon though, from my limited experience. "Brand-X" tools had the same issue. --- Quote End --- I've try to report issue. But I am not sure I done this by correct way. I have not found issue report service and post to [email protected]. - Altera_Forum
Hi Juzujka,
I think you should file a service request to Altera to report this issue. Check out the following link to sign up an account to file the service request. Note that you will require a valid company email to sign up the account. https://www.altera.com/mal-all/mal-signin.html?resource=%2Fcontent%2Faltera-www%2Fglobal%2Fen_us%2Findex%2Fmyaltera%2Fmal-home.html&$$login$$=%24%24login%24%24 - Altera_Forum
--- Quote Start --- Hi Juzujka, I think you should file a service request to Altera to report this issue. Check out the following link to sign up an account to file the service request. Note that you will require a valid company email to sign up the account. https://www.altera.com/mal-all/mal-signin.html?resource=%2Fcontent%2Faltera-www%2Fglobal%2Fen_us%2Findex%2Fmyaltera%2Fmal-home.html&$$login$$=%24%24login%24%24 --- Quote End --- Thank you, done. - Altera_Forum
Welcome. Any workaround suggested by Altera on this?
--- Quote Start --- Welcome. Any workaround suggested by Altera on this? --- Quote End --- No, my request was denied, because of my account level. :-( - Altera_Forum
It seems weird to be denied for a valid bug's workaround. Mind share further why it was denied?
you might try your design under 15.1. I've just done that and it fixed nearly all the lvds_rx issues I had for my Cyclone V design.
Regards Phil
