Balkesh
2 years agoPTP Adapter Error
I got the following error while compiling the program by choosing the component like rx port of Hard IP with ptp TOD Syncroniser and tod clock in order to provide timestamp to process the data in fif...
ZiYing_Intel
2 years agoHi Balkesh,
If you right click the 'ptp' file in platform designer and click "Edit Component Instantiation" (screenshot below), you will see the source file is actually referring to the one located in ftile ethernet folder rather than the one located in custom ip folder. You can just delete the file since you are deleting the culprit which confuses Quartus.
zying
